hi! I am having an issue w/ the paste special pop up window. When I select 'paste special' the pop up only shows a very small portion of the normal window. I cannot access any of the options or see what I am choosing. I'm not sure how/ why this is happening, but any suggestion are greatly appreciated. Image included.
are you following the procedures described here?
Use Paste Special with the clipboard—ArcGIS Pro | Documentation
Hey @TWill
What version of ArcGIS Pro are you using?
As long as you are selecting the items in the map with the select tool, pressing Copy or Ctrl+C and then using Paste Special, it should pop up. Have you attempted to save and restart the project so far?
Cody
