With HTML 5 coming, I think the JavaScript API is a totally sound development platform.Good Luck!
I'm going to nit pick a little...
I have primarily focused on web development using the Flex API (utilizing Flash Builder), but am thinking about transitioning toward the Javascript API. The main reason behind this is the need to provide cross-platform accessibility for our main application (we'll still develop using Flex, but those apps will be very task-specific).Does this logic make sense or am I imagining that Javascript is the silver bullet? Of the people that are already utilizing the Javascript API, what development environment do you use? Are there any packages out there that are more WYSIWYG than ones like Aptana?Thanks in advance!
I found the link below to be very helpful in my transition (particulary the "mobile" section). Still getting used to it though, not sure how to add more than one feature layer to the map and have it display in the dynamic legend (it only shows first layer for some reason)...let me know if this helps and if you can figure it out...http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples_start.htm
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
