My fire department wants to have a survey123 checklist for each vehicle for daily, weekly, and monthly check in.
We have 12 vehicle surveys each with a quite a few questions. We are running Enterprise 11.1 and these were made with survey123 connect.
What they now want is a way to get an email if something is missing from a vehicle (example Medication).
I have used power automate in the past and thought this would be perfect. Sadly it is not working. Due to having too many fields. Is there another way to get an email? I also cannot auto make reports either. I need those generated every day. In my research I have found that there might be a way to limit the schema down for just the yes no questions for the output to power automate but I am not sure how to do that. If I scale down the power automate it will not help me in the report because I need all questions.
Basically the survey is a bunch of yes no questions and if the answer is no there is a comments box that appears. Then each section has an option for images.
Here is my error:
The dynamic schema response from API '***' operation 'GetWebhookPayloadSchema' is too large, only schemas with at most '1024' properties are supported.
Any advice would be appreciated.
@IsmaelChivite
