Please see attached doc for better understanding.
I using ArcGIS Enterprise 10.9 for publishing survey, and Survey123 Connect 3.22.
And all my images/file extensions are lower case.
Thank you
Any spaces in the name?
It had before but I renamed it. No spaces in the name now
You said they are all lowercase but these are not. It can be any case but it is case sensitive.
Sorry for the misunderstanding. I meant the file extension in lower case ".png"The image cases are matching- the excel file in the survey with the name in the "image folder"
If it helps I have been using groups for help images that works pretty good. Can collapse or expand.
I've been reading some posts and looks like some users have similar problem.Anyway, can you give me an example of what are you saying ; "I have been using groups for help images..."Are you saying to do a begin group/end group with images??
My goal is having a thumbnail of the image or a small size that can be expanded.Thank you
Sorry I meant to add a gif but all our files are moving and could not get to it. Here is a new one.
Thank you Doug.I've opened this .gif file in photoshop, but not all the layers came up 😞
Doug,
Could you answer me a question? I know is off topic, but anyway…
How can one of my coworkers modify any of my survey form when I take vacation?
Survey123 saves its files to the user ‘c’ drive, and publish the form to the user account Enterprise or ArcGIS online.Any suggestion??
? it just plays right there in the browser
You can't. It is a big limitation. You have to fully change owners which is a process you do not want to do unless it is a one time thing.
Bummer!
