Hello,How do configure and receive alerts for ArcGIS Enterprise License and SSL Certificate Expiration in ArcGIS Monitor 2023?Any help would be appreciated.Thanks!
Hi @VarunKakkar, > How do configure and receive alerts for ArcGIS Enterprise License and SSL Certificate Expiration in ArcGIS Monitor 2023? Both of these metrics are not available in ArcGIS Monitor 2023 yet. Sorry. We do have these in the Dev backlog. Hope this helps,
I was just looking for that function. I'll put it in my backlog of "good things coming".
Hello Derek,Thank you for your response! Will be waiting for the feature in future upgrades.Regards,Varun
Hi @DerekLaw is there any update to the function of alerting on license expiration?
Hi @LHo,Sorry no updates on these items at this time.Hope this helps,
Any updates on adding these metrics in 2024.x?
Hi @René_Ténière,Apologies for the late follow up. Yes, we do have a partial update on this item. In ArcGIS Monitor 2024.x, under the Monitoring page > Components subtab - Monitor will display in the components table: i) the license expiryii) the CA certificate expiryfor enterprise portals and ArcGIS Server sites.We are working on enabling alerting for both these properties in a future release. Hope this helps,
Hi @DerekLaw,
I installed 2024.0.1 from scratch and I get the following. I also installed Enterprise from scratch (11.4):
Any thoughts?
Hi @René_Ténière,Sorry for the late reply, I was working at the Esri Federal GIS conference this past week in DC.
I have not seen this error before, is there anything special about the CA certificate that you're using? Can you please open a case with Esri Tech Support so they can help you look into this further?
Hope this helps,
Hi @DerekLaw ,
Nothing special, it is your standard DigiCert certificate with valid root and intermediate certs. All 3 have been uploaded to Portal and Server. I can open a case with Esri Canada Tech Support...
Hi @René_Ténière,> I can open a case with Esri Canada Tech Support.
Yes please. I would like to know if they can reproduce the behaviour you're seeing. Thanks.
