Sorry I thought I would try this one more time. Has anyone updated the addexcel widget for 3.3 that they care to share. I'm not real familiar with how to do this and figured/hoped someone else had already taken the steps to do this. If you have could you please take a moment to upload it for those of us who are not as experienced please. This would be a nice widget just to have with the main flex builder.
How do I handle this? I have my Flexview app in the coordinate system of my data.Any excel file that is in the same coordinate system will overlay properly.You could use ArcMap projection tool to re-project your stores FC to webmercator and add coordinates to it, then export the table. that would give you the "lookup table" that you mentioned.R_
Thanks for the quick response. Currently I have everything reprojected to web mercator because I am just using the default basemaps. This includes my shapefile. Should I project all of my layers as NAD1983 and then change the WKID to 4269? I should clarify, Change the WKID inside the flex config file.
