Good morning,
How do you recommend to share a layer that is located in AGOL in ArcGIS Portal to be consumed by a viewer in Portal.
Thanks
Hey @SanchezNuñez
You would be able to share via Distributed Collaboration, this requires an administrator to accept invitations and send responses on both sides:
AGOL:
https://doc.arcgis.com/en/arcgis-online/administer/create-a-collaboration.htm
Portal:
https://enterprise.arcgis.com/en/portal/latest/administer/windows/create-a-collaboration.htm
Cody
Is the layer on AGOL shared to everyone? If so, you can just add the layer by URL in the Portal viewer.
R_
Good morning @RhettZufelt
No the layer is not shared with everyone, but only with a group of people.
