We are currently using Windows ArcGIS Monitor Server and Agents. We will be supporting a new team that is all Linux.
Can Windows Monitor Server consume information from Linux Monitor Agents?
Hi @SteveMcCarthy,> Can Windows Monitor Server consume information from Linux Monitor Agents?Yes, you can use ArcGIS Monitor Server on Windows and register ArcGIS Monitor Agents running on Linux with it. This deployment should work fine.Hope this helps,
Thank you for the confirmation and that was the answer I wanted to hear.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
