How do you overcome this issue in ArcGIS Pro. There is no data associated with this feature class at the moment. I want to change a field name and alias to something else. I am also not able to delete it. ??
What is the field name?
The field name you attempted to alter may be a reserved field name, a required field, or contain invalid characters
Hello,
A schema lock was applied to the geodatabase. .... layer is lock. ....For your success remove the locks
