Hi Andreas,
The empty JSON file is an interesting case, as Data Pipelines doesn't know the schema, hence the data pipeline failing. We'll look into some possible solutions for a future release. Thanks for bringing this up!
Andreas, I can supply an alternative workflow and have a blog on the topic which I'm publishing November 7th when ArcGIS Pro 3.4 releases - because it uses a new feature. The subject matter is weather alerts in CAP protocol, which I can see is available in your weather feed. Empty entries are OK. I'll let the pipelines team respond on what you are experiencing.
Hi @AndreasHall,
As you noticed, scheduling pauses when a data pipeline fails after too many failed runs (5), and this functionality was built in intentionally to prevent users from paying for the running of a data pipeline that may have a critical issue that needs to be remedied.We will work to address this in a future release and will reach out to you if we need additional input. Thank you!
Thanks for the feedback!
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
