こんにちは ポップアップ内に学校名をすべて一覧表示し、ユーザーが学校を切り替えられるようにする Arcade コードを探しています。基本的には、1つの建物に複数の学校が入っています。ポップアップに学校名をリストとして表示したいです
Just clarifying as it's not super clear to me from the interface - is there a relationship class linking the building to the schools? And this is what's showing when you click on the building and expand the related schools? If not, what interface is this?
Hello @JoshuaSharp-Heward
no is just overlap polygon layers. no relationship class and when you click on overlap polygon layers popup in arcgis online. pop is like this which show 5 features overlap. it is just one layer.
Check the popup title display field.
It's likely using a field like {building_type} and you can change the title to {building_name}. This will give it a better appearance in pop-up lists.
hey @ChristopherCounsell Thanks for respond, I know about that. I am looking for to list everything in one pop up and don't want user to click to view list.
I think your data will need to be slightly restructured for that. With just one layer and overlapping points I don't think there's a great way to show the information from all five simultaneously - if you had a building layer or processed the data to have a single point per location then intersecting that with the schools layer and pulling through the names would be doable.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
