I created a Survey123 on the web (not using Survey123 Connect) and when I try to use it in the field the (2) drop downs (single answer) are empty...why?
What CSV?
I'm sorry, but I don't quite understand what you're saying here...when am I exporting something?
Form A: collects vendor company names.
Form B: collects vendor personnel names.
Both are continually being edited, with new vendors and personnel being added.
The first question in Form B is: select a vendor company name (via the drop down list) And in Survey123 designer, I have it looking for values from Form A.
But when I open this form in the field, that drop down list is empty...so I'm not saving anything as a CSV anywhere....
Id suggest checking that you are saving the the CSV format is UTF-8
This is usually special chars in the CSV, spaces in the name of the csv, wrong case on csv file name, or using pulldata with a calc inside of it or a pulldata inside a if().
If its none of those need post the form.
