I'm not sure if annotation groups are the best strategy for strip maps. Here is an quote from help:"Map document annotation is stored in map documents in annotation groups within each data frame. Choose map document annotation if you only want to use your text in one particular map."Two thoughts - 1) use basic labeling with horizontal options. or 2) mask the labels outside of your index polygon.It would be great if you could include a couple of screenshots.Thanks,Jeff
Justin,I must be missing something or not understanding the problem correctly. How is it possible that with DS MapBook or MapLogic that you were able to rotate annotation features for adjacent pages? Annotation gets rotated like map features, there is not an option to keep annotation horizontal. Only label features have that option.Please send screen shots so we can assess the issue.Jeff
The best way to handling this users case is to use the Tiled Label To Annotation tool. This tool was built to handle Data Driven Pages use cases as well as map service caching cases. Feed in the index layer etc. and set the field for identifying each tile so annotation will be tagged with the ID. It will convert labels to annotation in a separate run done specifically for each page with the correct rotation etc. You can use a Page Definition Query on the annotation layer to filter out annotation that doesn�??t apply for the page being viewed when the pages overlap etc.Craig
Craig,Thanks for the help, that sounds like it would work for most situations and we'll give it a try. However, it is often not desirable to query out the labels from adjacent pages if the features are still visible on the current page. There really needs to be an "angle relative to the current frame" option for annotation.Thanks,Justin
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
