@GeoJosh ,
Did the ability to use Group Managed Service accounts to run ArcGIS Monitor agents stop at 2024.0?
@CharlotteNCIT, it did not. GMSAs are still supported.
So when installing the new Agent for 2024.0 using the preexisting GMSA account that has been running the older versions it would not install. Anything you recommend checking? The GMSA account still has access to the servers and nothing has changed.
In order to be helpful, I will need more context about what you mean by "would not install". Is the installer failing? Are you seeing an error message?
Thats what I receive when I use the gmsa to install the Monitor Agent @GeoJosh
@CharlotteNCIT,
We are not able to reproduce this behavior in house. Two action items here:
1. Submit a case with Esri Support to investigate further.
2. Install as another account (domain or local, non-gMSA), then manually switch the service account via Windows Services if the installation is successful. =
Josh
