Hi there,
I have noticed inconsistent results in the ArcGIS for AutoCAD search.
For example, There are LINZ public layers that show up in the Living Atlas in ArcGIS Online:
That do not appear in the Same search in ArcGIS for AutoCAD:
Hello @Marc_Graham ,
Thank you for using ArcGIS for AutoCAD!
As my colleague mentioned depending upon what organization you have connected will determine what items are available but also I might for ArcGIS Enterprise it could differ with what version. I really appreciate the provided screen captures. The bottom one appears to be connected to ArcGIS Enterprise based on its name in the sidebar.
Here is ArcGIS Online without signing in:
Here is ArcGIS Enterprise 11.3:
Are you connected to an ArcGIS Online or ArcGIS Enterprise portal? The content of Living Atlas differs between Enterprise and Online.
Ah OK, thanks for that. Yes we re on an older version of Enterprise - 10.9.1, upgrade to 11.3 pending.
