While registering enterprise geodatabase in ARCGIS server the following error appeared , how to fix this error ?Thanks in advance
thank you for the commnets ... I am going to try this now
Which SQL Server native client is installed on the server machine?
The Microsoft ODBC Driver 11 for SQL Server is not supported by ArcGIS 10.2.1 or 10.2.2 clients. The SQL Server 2012 native client must be used instead.
System Requirements
I am using Arcgis for server 10.2.1,
created database using Sql server 2014,
Authentication type : Database authentication
Suad,
Can you provide some more information than just the error?
-What version of ArcGIS for Server?
-What RDBMS are you attempting to register to?
-What authentication is being used (DB vs. OS)?
That should get us going.....
