Hi, i need a help. i have lot of point and lines in my feature class which in geodatabase.i found some of the points and lines are duplicate.can any body help how to find duplicates using Arcobject with C#?
shorten your title please
Try building an ephemeral topology with the appropriate rules specified. This will allow you to detect coincident points and overlapping lines when you validate the topology. Once you have cleaned up your data, delete the topology.
Do you have to use ArcObject? Why not try the Find Identical GP tool? And there's another GP tool that will remove duplicates, Delete Identical GP tool.
