Hi
I'm loading world topo & sattelite map to mapview, when i pan it shows missing tiles.
Same thing when working with local tpk files which are much much smaller.
How can i set the scale of the zooming&panning to the limit of available tiles?
I would suggest that you look at the setExtent method found on the MapView object:
MapView | ArcGIS Android 10.2.7 API
This may contain the information that you are looking for.
I know setExtent, requires 2 points bot-left to top-right.
I tried playing with it.
path = SATTELITE_BASEMAP_SERVICE_URL;ArcGISTiledMapServiceLayer layer = new ArcGISTiledMapServiceLayer(path);mapView.addLayer(layer, 0);Geometry boundries = layer.getExtent();mapView.setExtent(boundries, 0);
Not working with online & tpk maps.
