Hello. Had anyone encountered this error message indicating that “ The document already has a "Document Element" node' when attempting to edit metadata of a feature layer?
We are now experiencing this as well, on data exported originally out of Enterprise Portal 10.9.1 and brought locally as fgdb into Pro for metadata addition
Good day, I have had the same issue. Currently in search of an answer as well.
We just ran into this exact issue today as well, but our Enterprise Portal is version 11.1
I’m experiencing the same issue. Has there been any resolution?
Same issue here in Enterprise 11.1.
Hi everyone, we appreciate you sharing a potential bug with the broader Esri Community; however, Esri does not actively track software defects posted here. The official channel for investigating and validating bugs is Esri Technical Support. All customers experiencing a potential software bug should leverage technical support to report and investigate the issue.
By reporting bugs through technical support, Esri can better track the scope and impact of the issue across all our customers and better prioritize it with our product teams. Our teams can also investigate the issue more thoroughly to see if there is a solution, workaround, or patch to get you back up and running as soon as possible.
As a reminder, Esri Community is primarily a self-service support platform where Esri users can ask or answer each other’s questions, share feature requests, and collaborate to solve problems with GIS.
*Note that this is a scripted message prompted when posts allude to a potential product bug.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
