Workswell WIRIS Proカメラで撮影したサーマル画像からオルソモザイクを処理しようとしています。私の画像は放射計TIFF形式で、デジタルピクセル値は約5000から7000の範囲にあります。しかし、出力されたオルソモザイクのデジタル値は19から26の範囲でしか変動しません。出力が正しくなるように、何か設定パラメータを変更する必要があると思います。どなたか助けていただけますか?
Hi @FranciscoCáceresClavero, We don't have any testing data for that specific camera model, but it sounds like it is processing for you and possibly also doing the thermal temperature calculation. In cases where a drone is not supported for thermal processing yet in Drone2Map the true ortho result will only be the pixel values. We are able to add support for new thermal cameras though so if you are willing to share the data I can take a look to see what might be going on with the processing. Please feel free to email me so we can setup a shared folder: mbarker@esri.com
Regards,
Mark
Francisco
Do those values appear to be incorrect for your project site, assuming the pixels represent temperature in degrees Celsius? I was going to show you that you can convert temperature units to Fahrenheit under Settings
...but I assume this project is in Spain, and you'd want Celsius. (Note if you change units, you would have to reprocess).
Were you hoping to create a mosaic showing the original pixel values, from 5000 to 7000?
Cody B
