We have encountered this issue with one of our field maps (the others work fine) and was wondering if anyone else has encountered this error message and how they resolved it. We are currently using ArcGIS Pro 3.1.1 and Enterprise 11.
Any suggestions would be greatly appreciated!
Hi @mispisi
This looks as though someone has changed the schema of a layer or layers whilst this project has been taken offline, or overwritten the service that has been taken offline.
Please see the following documentation which should assist in retrieving the offline edits
Access offline edits from ArcGIS Field Maps directly from an iOS or Android device
Hi @DanielFox1
Thank you for your response. We had disabled the offline option for our field maps so I don't think that is the issue. I might look into the schema change a bit further though. I'm very curious about why this happened.
返信が遅れて申し訳ありません、結局のところバージョニングに関することでした。
