In WAB the ellipses would appear on the pop up window with navigation for directions to the location. How do you build this in EXB with the widget for the ellipses to appear? See screenshots.
In EXP, the ellipses is missing in the pop-up window.
Now the direction from/to actions can be found in the data action drop-down.
Thank you, the navigation widget will work for points, but not for polygons. Need the navigation widget to work for polygons.
