I am trying to symbolize a layer on Quantities -> Natural Breaks -> Jenks. There are some null values in the column that I'm using for the symbolization, and that causes those features to disappear from the map when symbolized. Is there a way that I can set a default value for the column so that this will not happen?Thanks
There might be a simpler method than this - but you could add a field, then use field calculator to fill it with the values from the old field. Then use Select by Attribute to select all the rows with a value of NULL, then use Field Calculator again to replace this null value with a different value.
Yes, I tried that too. But because you want to symbolize Quantities, you need a number field and the only way to use Field Calculator is with a Text field so unfortunately this won"t work.
:S Well it isn't working for me. Every time I try to use Field Calculator on a number field it is grayed out. Why would that be?
Okay I found a way to make it work... although I still think there should be an easier way. I created a new field and used Field Calculator to define the values from the column I was working with. However, if I just did them all at once, all the <NULL> values became zero which I couldn't have but I also couldn't define them as No Data because it's a number field and won't accept text. So first I used FC to make all the <NULL> values a value outside my existing range of values, then calculate the rest of the values normally. Then I classified the values to that the new, outside value was in a class on its own and I changed the label to "No Data". I think this is harder than it should be but at least it works I suppose. However my issue now is that, because I had to use a higher value than the rest, "No Data" appears on TOP of the rest of the values in the legend where I think it should be at the bottom, under 0.
You can change the order symbols display in the legend using the up/down arrows on the symbology tab.I don't understand what the problem is with calculating the field before the join (couldn't you calculate it in the table first, using Excel or similar?), but in any case, once you've joined the table you can then export the whole thing to a new feature class and use that. FC will work on that.
