Hello,
I am starting to explore creating a custom theme for Experience Builder Developer Edition. I am following the guide at Theme development | ArcGIS Experience Builder and have also tried the demo theme mentioned at Override theme variables | ArcGIS Experience Builder. In Experience Builder, when I go to the "Theme" section, my custom themes do not show up. Is there something else I need to do to get them to show up there?
Thanks
Josh
Hi, Josh
Try this trick: add an empty "style.ts" file to the theme folder, and rerun npm start.
This is a bug related to the webpack that is not watching for changes other than js or ts files.
Yiwei
Hi, This is Yiwei from the ExB dev team.
There might be two causes that your custom theme does not show up:
Try these methods and let me know if your problem has still not been resolved.
Best,
Hi Yiwei,
That worked. Thanks!
A related theme question: In client\dist\themes\, there is a calcite theme folder but calcite does not appear as a theme option in experience builder. Is that a bug, or is that calcite folder used by other themes?
ThanksJosh
Are the properties for the manifest.json file actually documented anywhere? If not, is there a plan to document these in the future?
