We updated two Arcgis Monitor environments to 2023.3, but the hosted features are not being listed.Any suggestions for having the hosteds?
Hi @EdnaKanazawa,Collecting metrics on hosted feature services is only available for ArcGIS Enterprise 11.1 and higher. Can you please confirm that your registered GIS Server components are at 11.1 or higher?
Hope this helps,
Hi @DerekLaw ,
It is 10.9.1 😞
Thanks
hei, I am Using version 2023.3. 1 on AGS 11.1 not able to collect metrics on hosted features. Hints ? @DerekLaw wrote:Hi @EdnaKanazawa,Collecting metrics on hosted feature services is only available for ArcGIS Enterprise 11.1 and higher. Can you please confirm that your registered GIS Server components are at 11.1 or higher?Hope this helps,
Hi @RengifoOrtega,I'm not sure what you're asking. Based on the screenshot you posted it looks like the hosting server registered with ArcGIS Monitor, it detects a hosted feature service and it is working fine. Metrics are being collected, but there is no activity on the service, which is why the request rate is zero. Can you please confirm there is activity on the hosted feature service?Hope this helps,
Hi, Sorry for the lacking information. I forgot to mention that the hosted services is a Geoevent services.
Best regards
Rengifo
Hi @RengifoOrtega,> .... I forgot to mention that the hosted services is a Geoevent services.I'm still not clear on what you're asking. Did you register the ArcGIS GeoEvent Server as a component with ArcGIS Monitor? Register ArcGIS GeoEvent Server And if so, are you asking about the collected GeoEvent Server metrics?(which are listed on the link above) For example, the events received and events received rate? This would appear when you view the ArcGIS GeoEvent Server component page(s).In your screenshot, it looks like you're viewing an ArcGIS Server component page.Hope this helps,
