How to drag a feature layer from table of contents and drop to textbox in ArcGIS Pro SDK in custom dock pane?
I am using the following example as a reference.https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Framework/DragAndDrop
Any inputs will be appreciated.
Thank you,Abhijeet
Hi Abhijeet
To allow a Dockpane to be a " Drop Target", please check the info in this section of the ProGuide: Dockpanes.
