Is there a way to bring and access web map from web page in my ArcGIS Online and interact with it.
@AshrafAyman6 - Sometimes you can view the inspect the source of the webpage to find the link to the data source. It will need to be a supported data source ArcGIService/WFS/WMS, etc
What webpage are you looking at? Example - Assuming it is a ArcGIS service, you can "inspect" the map to reveal some data.
Which tells me the data is coming from https://apps.dunedin.govt.nz/arcgis/rest/services/Public/Street_Map/MapServerYou can then add this data to AGOL by selecting the "Add Data via URL" option.
Hi @AshrafAyman6
If you are asking how to embed the map into another webpage, you can follow these steps:
Here is a video that will walk you through the steps and provide a visual guide to help you embed the map into your webpage.
Hi @gis_KIWI4 , I want to thank you about your response, but my question was about access the data on this web map with popup data and styleshttps://ballotpedia.org/California_State_LegislatureI saw that the data in html div with the geojson and popup attributes, what the best way to take the layer with style to my arcgis online?
Hi @EmilyGeo , I want to thank you about your response, but my question was about access the data on this web map with popup data and styleshttps://ballotpedia.org/California_State_LegislatureI saw that the data in html div with the geojson and popup attributes, what the best way to take the layer with style to my arcgis online?
You can't copy a web map from an outside page. You'd have to find that map within AGOL living atlas and play with the data from there. You could always reach out and see if they would provide a link to the map or layers in AGOL.
