数ヶ月間Share Packageを使用した後、突然うまくいかなくなりました。 同じ実行で成功と失敗の両方が表示されることはありますか?
<\/P>
完了と表示されますが、AGOには何も表示されません。
サイズは52 GBですが、以前はもっと大きいものも処理したことがあります。
ありがとうございます
I had a layer package not work for me. I went into the Control Panel to the Uninstall programs page. I did a "Repair" on ArcGIS and things worked properly again. It might be worth checking out.
Thanks but I have tried 3 different machines now all with the same result. Going to try at home.
Do other packages work for you? What I'm asking is, is it just this one? And if so, can you find the original data and try re-packing it again?
Did you ever work it out? We are having the exact same experience here with a 21GB tpk.
I am having the same problem as well. It worked a week ago, but now I had to recreate it and it will not push it up or it stays at 0%. Any solution?
Hello,
Please check for you Mdx file which you are trying to share as package.
Some time its happen SQL query are not supported in ArcMAP like !=.
Check and publish/ share package again.
Thanks.
Nope never did get it to work. I have to take the tpk to my house every time i want to upload. We are also still having some login issue with the Android SDK.
