If your system files are unauthorized modified then Windows 7 crashes can occur. Start scanning your system files and replace them with their original versions.
Data Recovery Scams
Thanks for the reply. First, I thought I would let you know that we've been working with Esri on this and they have been able to reproduce the issue and have logged a bug report. However, they haven't been able to identify the problem or offer a solution, yet. BUT, yesterday I was testing an idea we had and maybe this will help. In my test, if I uncheck the IE10 Internet Options->Connection->LAN Settings "Automatically detect settings" setting Build 1500 seems to work. Additionally, esri tried it yesterday, too, and they said that didn't work for them but what did work was checking "Use a proxy server for your LAN" and "Bypass proxy server for local addresses." Perhaps it is worth a try? And I'm curious to learn if it does/doesn't work as further testing of the idea.
Btw, the idea came from the report that unchecking that setting in IE10 fixes an often reported problem with Build 2500. The thought is that it could impact Build 1500, too.
Mary Ellen
Mary Ellen,
I haven't found any answer besides rolling iE back to 9 every time it updates. After I roll it back, I search for Windows updates, then go in and hide any IE updates. I have about 25 users who seem to get staggered IE updates so I don't have to do them all at once. I'd have to figure out something automated if I had more users.
Hi. I know it has been nearly a year since you reported this problem, but I am wondering if you ever found an answer. We are experiencing the exact same thing (but with build 1500) since we started pushing IE10 out to our users last weekend. All was fine in IE9 and Build 1500. Then IE 10 was installed and it appears that every ArcGIS Explorer Desktop no longer works properly.
Thanks,Mary Ellen
the easiest way to get rid of the "ArcGISConnectionBin.exe" error is to go into the folder where ArcGIS Explorer is installed and rename the "ArcGISConnectionBin.exe" file (for me it's in C:\Program Files (x86)\Explorer (x86)\bin).This will stop ArcGISConnectionBin.exe to load when opening Explorer. This will not affect anything with Explorer.The error is caused from having IE10 on the system.
Mark,My laptop has an Nvidia NVS 5200M graphics card in itI will post an update after updating my drivers
