i think a good way to do that will be implementing getting a screen shot and opening the SaveAs diagram to save it as a .jpg or .png...you can create your own custom menu via javascript, let's say onRightClick you open your custom menu with saveAs button, and the saveAs button includes getting a screen shot as mentioned above.grtz,mostafa.
The only client-side solution I am aware of is querying all the the imagery URLs and relevant styling information in each layer of interest and generating the HTML for a new window containing those URLs and then printing that window. Of course ArcGIS 10.1 has a print service.
Hi Mostafa, thank you for the response. Is there any way to do this after the map load, instead of user saving the map.
createPrinter: function () { var transformers = {}; return { register: function (transformName, transform) { transformers[transformName] = transform; }, print: function (options) { var self = this, map, output, features; map = dojo.byId(options.map); output = dojo.byId(options.target) || dojo.create("div"); features = dojo.filter(options.features, function (f) { return transformers.hasOwnProperty(f); }); dojo.forEach(features, function (f) { self.render(output, transformers(map, options)); }); return output; }, render: function (div, imagery) { var images = imagery.images; if (images) { images = dojo.map(images, function (item) { var img = dojo.create("img", { src: item.src }); dojo.style(img, { position: "absolute", left: item.x + "px", top: item.y + "px", opacity: item.opacity || 1, zIndex: item.zIndex || 99 }); if (item.w) { dojo.style(img, { width: item.w + "px", height: item.h + "px" }); } return img; }); } dojo.forEach(images, function (img) { div.appendChild(img); }); if (imagery.polylines) { // render vector data } } }; },
print: function (node) { var printer; printer = createPrinter(acme.gis.mapdrawer.render.createPrinter()); var div = printer.print({ map: agsMap, features: ["layers", "markers"], target: node }); dojo.style(div, { position: "relative", overflow: "hidden", width: $.todo("960px", "move to frame?"), height: $.todo("600px", "move to frame?") }); return div; }, function createPrinter(print) { print.register("markers", function (map) { var images = []; dojo.forEach(map.graphicsLayerIds, function (id) { var layer = map.getLayer(id); dojo.forEach(layer.graphics, function (graphic) { var geom, symbol, point; geom = graphic.geometry; symbol = graphic.symbol; if (geom.type === "point" && symbol.url) { point = map.toScreen(geom); images.push({ src: symbol.url, x: point.x, y: point.y, zIndex: 10 }); } }); }); return { images: images }; }); print.register("layers", function (map) { var images = dojo.query(".layersDiv div img", map.root); var root = dojo.position(map.root); images = dojo.map(images, function (img) { var pos; pos = dojo.position(img); return { src: img.src, x: pos.x - root.x, y: pos.y - root.y, opacity: dojo.style(img, "opacity"), zIndex: dojo.style(img, "zIndex") }; }); return { images: images }; }); return print; }
Use the print widget or the print task. Here's a simple sample showing how to use the print dijit.
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
