<?xml version="1.0" ?> <configuration> <title>{Marktyp}</title> <fields> </fields> <showattachments>true</showattachments> <showrelatedrecords>true</showrelatedrecords> </configuration>
You say so you can edit, so when you say information table, are you refereing to a popup infowindow, or the attribute table widget or edit widet table as they have to be enabled differently.R_
