hereby I am attaching the screenshots of the app. 1 screen shot that the map loads perfect and the other one when the issue comes.
I can share the code upon request
try targeting your audience https://community.esri.com/docs/DOC-1544
move to https://community.esri.com/community/developers/native-app-developers/arcgis-runtime-sdk-for-net?sr=search&searchId=1bc799af-0b64-481b-b14b-90a4d5cd1add&searchIndex=0
Have you checked if there are any errors when the layer is loaded?
No I am not getting any errors/exceptions. If it is the case, i should not get the map all the time. but the issue is intermittent. at some point of time only i am not able to see the map
Could you share a reproducer so I can have a look?
Hi Antti, I have attached the sample code along with my question (Due to size issue, couldn't upload the whole project). Kindly see to it. I am sorry to say that, the issue can not be reproduced in the first execution attempt itself . it is intermittent. We cannot predict when it will come. Is there any possibility that it is because of a network issue? Thanks in advance
PS: It is Windows 8.1 Store App. i have used "Install-Package Esri.ArcGISRuntime" command to install the arcgis package.
Unfortunately I cannot reproduce this. I ran the application maybe 50 times. I get the basemap loaded everytime even though sometimes it takes a bit longer than other times. In this case, we are talking about some seconds but the tiles comes down even in high network pressure. Make sure that you have a hook on MapView.LayerLoaded and make sure that there are no errors there. Network might be one player in the game but at least for me, everything seem to work just fine.
Do you have any corporate firewalls etc that might be part of the problem?
Try to reproduce the issue while running a tool like Fiddler to see if you can see any errors / not returned tiles there and share the logs when you get the issue visible.
Thank you Antti. I Will try with MapView.LayerLoaded once and with Fiddler once .
