hereby I am attaching the screenshots of the app. 1 screen shot that the map loads perfect and the other one when the issue comes.
I can share the code upon request
try targeting your audience https://community.esri.com/docs/DOC-1544
move to https://community.esri.com/community/developers/native-app-developers/arcgis-runtime-sdk-for-net?sr=search&searchId=1bc799af-0b64-481b-b14b-90a4d5cd1add&searchIndex=0
Have you checked if there are any errors when the layer is loaded?
No I am not getting any errors/exceptions. If it is the case, i should not get the map all the time. but the issue is intermittent. at some point of time only i am not able to see the map
Could you share a reproducer so I can have a look?
Hi Antti, I have attached the sample code along with my question (Due to size issue, couldn't upload the whole project). Kindly see to it. I am sorry to say that, the issue can not be reproduced in the first execution attempt itself . it is intermittent. We cannot predict when it will come. Is there any possibility that it is because of a network issue? Thanks in advance
PS: It is Windows 8.1 Store App. i have used "Install-Package Esri.ArcGISRuntime" command to install the arcgis package.
