I would like to add an additional item to the map context menu in ArcMap 10.1. Specifically the context menu when you right click over the map. Here's a picture:[ATTACH=CONFIG]28542[/ATTACH]I found the following post (http://forums.arcgis.com/threads/40395-Need-ProgID-for-context-menu-properties-command) that talks about going to Customize -> Customize Mode and then selecting the Context Menus toolbars, searching for the context menu you want to modify and then getting its GUID from the registry. However, I am not finding the above menu. Have I overlooked something? I can't believe this is one of the context menus that can't be modified.Anyone else know what the GUID for this context menu is?Thanks!
Hi,I hope that you are looking for this:http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/index.html#//00010000029s000000
the context menu you are looking for is the data view context menu:[ATTACH=CONFIG]29129[/ATTACH]
