Is there a method available to query 3 or 4 feature services into a "LIVE" single table for use in an ArcGIS Online (AGOL) Dashboard? If not, are there any workarounds or alternative approaches currently available?
You could create a Data Expression that aggregates data from several services.
You would need to set a refresh interval to make it "live"
https://doc.arcgis.com/en/dashboards/latest/get-started/create-data-expressions.htm
Jill
Thank you so much for your reply, Could you please help me to write the expression that query 3 or 4 feature services, and I will edit it accordingly.
Thanks in Advance
