The Instant app slide isn't displaying in the correct location; regardless of the configured position, it consistently appears at the bottom of the map. This problem is specific to the portal, as the app functions properly on ArcGIS Online.
Hello Aymen,
Thanks for sharing with us your Sidebar issue in Enterprise environment. This issue is a known issue and have been fixed in the upcoming ArcGIS Enterprise 11.3. Here is the defect info: BUG-000163830 for your reference.
Regards,
Julia
Hello @JShi_EsriStaff - have you following or have seen this post:
https://community.esri.com/t5/arcgis-enterprise-questions/11-2-upgrade-instant-apps-config-won-t-come-up/m-p/1405521#M39154
I ask simply because we have a failure somewhere in our upgrade from 11.1 to 11.2, and apparently not everything installed because I can't even launch the InstantGallery page. . . the TS can't find other js and node modules... I'm working with support but if you have anything you could add my support case number is
Esri Case #03592799 - 11.2 Instant Apps configuration page will not display
Thanks-
David Coley
Sarasota County GIS
Hooray! The sidebar is back in place and functioning correctly at 11.3 @JShi_EsriStaff ! Thanks to you too @KellyHutchins !
