交通標識の台帳作成にあたり、土木技術者と協力しています。標識は特定のMUTCDコードごとにグループ化され、レイヤーには適切な名前が付けられています。ポップアップにはレイヤー名ではなく、MUTCDコードを表示したいです。
例:コードW10-1、W1-6、W1-8、W1-2Rは「Warning - Other Signs」という名前のレイヤーにまとめられています。ポップアップにはMUTCDコード(例:W10-1)ではなく、レイヤー名が表示されます。
どうすれば修正できますか?
In your popup configuration panel as i've shown below - in the Title area you put in the field you want to show as well as other text you want to add for formatting. You pick the field you want from where the little { } show on the side of that dialogue.
Thank you clt_cabq. However, it still wants to use the layer name in the title rather than the field value. Labeling works to show the MUTCD code correctly though. 🤔. An option would be to duplicate the field used for the grouped symbology and treat it as if.
There's another place where the title can be configured in the popups window - under the Field List, you might check there to see if that's been set up independently of the main popup? Its kind of weird in some ways that you can do this but I'm sure there is a use for it.
Do you want to populate the Popup title or the (attribute) list title with the MUTCD code?
R_
@clt_cabq I ended up duplicating the field to accomplish the goal for the labeling, but created a new issue of not populating the original field necessary for symbology.
@LukeSnyder how are you grouping your layers? is it in arcGIS Pro then published that way as a hosted service? or are you grouping them in the the the webmap? And I am wondering in the latter case if it matters where you are configuring your popups, before you group things, or once they are grouped?
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
