I have one giant polygon then I used the edit tool to slice and divide the areas to make different land types now it has weird gaps and overlands cause I accidentally moved a lot of polygons. What can I do to make it all fit? Thank you
There is this thing called "topology" that is used for this.
Basically, you
There are topology tools that allow you to decide what to do with the overlaps or gaps: that is to assign them to one side or the other of the overlap or gap.
Hope this makes sense and helps.
