こんにちは GIS フレンズ!
ArcGIS Enterprise の QuickCapture で Power Automate を使用できますか?また、Power Automate 用の QuickCapture コネクタ手順リンクを提供していただけますか?
ありがとうございます、Abi
Hi @AbiDhakal Esri does not offer a Microsoft Power Automate connector for ArcGIS QuickCapture.
If you would like to automate tasks with Power Automate when data from the QuickCapture mobile is sent into ArcGIS, I suggest you configure a webhook in your QuickCapture project's layer and then use the ArcGIS Power Automate connector.
Alternatively, you could use the Make.com (formerly Integromat) QuickCapture connector as described here: https://community.esri.com/t5/arcgis-quickcapture-blog/data-enrichment-with-arcgis-quickcapture-and/ba-p/892203
@IsmaelChivite - Thank you!
