Hi all,
I don't know what exactly happened after updating to ArcGIS pro 3.2.0, but the horizontal scroll bar in the catalog pane disappeared (see screenhot). That's really frustrating! Any help would be appreciated.
Thank you in advance
Simone
So this is BUG-000163295 - "In ArcGIS Pro 3.2, the scroll bar is missing in the Catalog Pane." It's currently under review and hopefully will be fixed soon!
Will it also be fixed in the Table of Contents in 3.5?
Hi @SimoneSilvestro - correct. ArcGIS Pro 3.5 will have this issue fixed and will be released publicly sometime the first or second quarter of 2025. I am not on the ArcGIS Pro Development Team so have zero influence on bug fixes or release dates.
Hi @Robert_LeClair Thank you very much for your reply. Not sure I got what you mean when you say 'Figure Q1 or Q2 of 2025 that this will be available'. Do you mean I should wait 2025 for having this issue fixed?
Thank you again!
Good morning @SimoneSilvestro - I'm seeing BUG-000163295 is fixed with ArcGIS Pro 3.5 so not yesterday's ArcGIS Pro 3.4 release sadly. Figure Q1 or Q2 of 2025 that this will be available. Sorry to be the bearer of bad news.
@Robert_LeClair I am seeing here https://support.esri.com/en-us/bug/in-arcgis-pro-32-the-scroll-bar-is-missing-in-the-catal-bug-000163295 that the bug is marked as 'fixed'. However, it is not, as the horizontal scroll bar is still missing in ArcGIS Pro 3.4.0. Any hints? Thank you very much!
@Simonez - the bug is under review currently. You can track it's progress here.
@Robert_LeClair do you know how the progress on this can be monitored? Running the 3.2.2 version and the issue hasn't be addressed.
You're welcome! Fingers crossed that it's fixed soon!If you feel my response was the correct answer, please click the Accept as Solution on my response to close this thread. Thx!
@Robert_LeClair many thanks! Hopefully it will be fixed soon.
Thank you for your help but this is not an acceptable solution for me. Widening the pane would squeeze the map view which is a pain, especially when you have long raster data names (or whatever). I need the horizontal scroll bar back.
use the sizing handles and widen the pane
