From the sample code, the redirect URI is as follows:
Hi,When we register your app for OAuth, we have to specify the re-directURI. For a given ClientID, only the registered re-directURIs are allowed. For the sample, the redirectURI allowed is `authenticate-with-oauth://auth`. You need to register your own app.ThanksRama
Yes, I am already doing this. I am registering different redirect URIs to my ESRI Application for the given client id. When I reference any redirect URI I already have set that isn't `authenticate-with-oauth://auth` then I just get the infinite loop of being prompted to login. Why is this the only redirect URI that actually navigates back to the app?
Can you share the other re-directURIs format that you specified at the time of registering the app? The browsers expect it to be <my-custom-app-scheme>://<my-custom-app-host>. The semi-colon with two forward slashes is requiredThanksRama
The main one that I was using was "MobileMap://auth". I had this set as a redirect URI for my ESRI application and also was in the Android code as well (DefaultOAuthIntentReceiver in AndroidManifest.xml and OAuthConfiguration in MainActivity).
The re-direct URI seems fine. Would it be possible to share your repro code (using a temporary account) via a direct message or provide network logs via direct message or debug your app through our support?
Hey Rama, I appreciate your help on this. I believe that I do actually have it working now. I'm not allowed to share the source code but in case I end up having issues again with this I could pursue one of those other two options.
