When I use the search widget in my EB map, it will auto select and pan/zoom/flash the polygon I want based on the search criteria. The other thing it does is it filters the data and hides all of the other non-selected features until I click the "X" and wipe out the search criteria. I really need it to NOT filter/un-show the non-selected features and continue to select/flash the one I searched for. Is this possible? I can't find a setting anywhere in the widget that controls this.
This was added in Experience Builder 1.12, equivalent to Enterprise 11.2.
I think you will need to make a copy of the search widget and add the code yourself.
The standalone Search Widget does not need to be used with a Map Widget and it is possible to use it on a feature without geometry, so that is probably why the marker is not a default option.
Anyone know if you can add a marker when using the search widget, I know it has it if you use the standard search?
I'm guessing that's something they've added in the newer version on AGOL. I'm using the enterprise version, so it doesn't appear to be an option:
Toggle this setting off seems to do that.
R_
