Hello,
I am trying to build an SQL statement to find records where two concatenated fields are equal to a third field. Specifically I would like to build the following statement
CONCAT(field1, " ", field2) = field3.
Is this possible?
Thanks!
Hey Lyon,
This is valid SQL from the looks of it, I've just attempted this exact CONCAT function and it had worked with me. Specifically like this:
SELECT *FROM TestTableWHERE CONCAT(field1, ' ', field2) = 'Work Flow';
I believe this is what you're asking!
@CodyPatterson
I am still having trouble. The SQL you have looks perfect for regular SQL statements, but is complaining when I try to create a definition query or select by attribute 😞
This works:
CONCAT(ST_NAME, LOCATION) = ROUTE_NUM
This does not work when I try to add a space:
CONCAT(ST_NAME, ' ', LOCATION) = ROUTE_NUM
Thank You
Sorry for the late response, you may try giving this a shot, I've heard that ampersands work as well:
field1 & ' ' & field2 = field3
This is without CONCAT as well, could possible get somewhere, but I will keep looking if that doesn't end up working!
Cody,
I figured it out. ArcGIS does not understand the regular + character when we want to concatenate a field value with a string. But it does understand a double pipe such as:
ST_NAME || ' ' || ST_POS_TYP = ST_CONCAT
