private void centerAndZoom(ESRI.ArcGIS.Client.Map map, ESRI.ArcGIS.Client.Geometry.MapPoint mapPoint, double resolution) { double ratio = 1.0; if (map.Resolution != 0.0) ratio = resolution / map.Resolution; if (ratio == 1.0) map.PanTo(mapPoint); else { ESRI.ArcGIS.Client.Geometry.MapPoint mapCenter = map.Extent.GetCenter(); double X = (mapPoint.X - ratio * mapCenter.X) / (1 - ratio); double Y = (mapPoint.Y - ratio * mapCenter.Y) / (1 - ratio); map.ZoomToResolution(resolution, new ESRI.ArcGIS.Client.Geometry.MapPoint(X, Y)); } }
