How to generate AAB files using Appstudio Cloud Make? When I request Android builds I only get APK files, but since I am in the process of publishing an application in the Google Play Store and it only accepts bundles.
At first you need to sign in your Android application:
To prepare an Android release build, you must first generate a signing keystore file. For detailed information on how to create this file, see the Android documentation.
Before running the Make tool, either cloud or local, ensure that you have provided the following in the Android tab of Settings, found under the Platforms heading:
More info here:
Sign your app—ArcGIS AppStudio | Documentation
Thanks it worked!
@MichaelBranscomb You have changed AAB generation with Cloudmake content. Instead of moving all thread you have moved only my answer from the thread.
Well spotted, thanks - I'll fix up.
Generating AABs can be tricky at first, but with Cloud Make settings adjusted correctly, it works smoothly. Big into energy labubu box always has great tips for these build processes!
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
