On the S123 documentation for report templates (https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereporttemplates.htm#ESRI_SECTION2_EC422F86913F4CC497B59E3F82B5AB4E) there is a typo. In the list of methods and parameters, countSelected is listed as 'countselected' (lowercase 's'). I was obeying the documentation but then also saw it provided correctly later in the documentation as 'countSelected'.
Just FYSA if Esri wants to correct the typo. It caused problems with a template but changing to camelCase cleared it up.
@jmcewen_ddg Good find!
Right in the doc, if you scroll down to the bottom, you will find a Feedback on this topic? link. This is the best way to report this type of findings. I just sent a note to the documentation team using that link in the help topic you referenced above. Thanks a lot for reporting this! Great find!
