皆さん、こんにちは。<\/P>
お元気でいらっしゃいますか。<\/P>
ESRIのプレゼンテーションで、カメラの位置と撮影された写真のテンプレートを見た記憶があります。プレゼンテーションは手元にありませんが、誰か覚えていますか?<\/P>
追伸:プレゼンテーションには複数のESRIツールとソフトウェアが含まれていたので、Site Scanかもしれません。<\/P>
よろしくお願いいたします。<\/P>
@QuickSnail I think then you are referring to Oriented Imagery. Take a look at the example applications here. I think the example you are after is 3D Chateau but there are other examples which do what you are after. OIC becomes part of ArcGIS Pro at the November release. No just an add-in
Hi Gordon, close but not exactly. Cheers.
The template was showing the target picture and as an inset map overall position of the drone and camera cone view (nadir , oblique) in relation to target .
Hello @QuickSnail I think you'll find it is in this video at miniute 25 and the capability will be available in Drone2Map 2023.2 in November
