I am trying to use the calculate feature in survey123 connect to generate a score by adding up all the fields. I have ran into an issue adding up more that 6 fields. I have the responses set as yes=1 and no=0, the survey will add up the first 6 fields, if add more fields to the equation, stops adding the responses and just displays the responses rather than adding them together. Any thoughts or suggestions?
