Greetings, I am experiencing an Error in several surveys123 embedded in a dashboard. It generates the following error:
Hi @AlexUreAl , we just push a hotfix version on production. Could you please try again, see if the error still exist or not?
Hi @AlexUreAl ,
Thanks for reporting the issue. I am wondering is there any select multiple question with search appearance in your survey?
Ruth
Hi Ruth!
I don't think so, I'll share with you the details of what the survey contains:
Hi Rut, I checked and the boards are now working correctly. Thank you for your collaboration.
