I have a script that I use to convert text files into LAS files- there are 400 files. How would I make a batch script or loop to tell Python to keep grabbing the next file and keep converting until it reaches the end of the folder?
You can loop through a folder to get all your text files.
import os folder= r'path_to_your_folder_of_text_files' for root, dirs, files in os.walk(folder): for filename in files: input_file = os.path.join(root, filename) # You can then run your conversion script here # Use input_file for your input into your script.
I would look into using arcpy.da.walk.
Hi Jackie,
You could try something like the following:
import os for filename in os.listdir('dirname'): if os.path.isfile(filename): # code to convert file here
<SPAN class="kwd" style="color: #00008b;"></SPAN>
Or, since this isn't ESRI data specific, you can use regular old os.walk.
